Purchase Requisition WorkFlow
Dear All
I want to create a Purchase Requisition workflow in which user creates a purchase Requisition then that requisition should go to his HOD for approval than finally it should go to Purchase Department for Approval
Now the problem is each department have its own HOD, how can I create this Work Flow in AX-2009
Regards
Muhammad Saad
What is the problem you are facing in doing that???
Dear Kranthi
The problem is how to define hierarchy and making relation of users and head of departments.
Regards
Muhammad Saad
how it is configured for a particular user?
You may try this.
First, in the employee list, assign the employee to the respective dept/ group. Example:
Ali – Purchasing
Abu – Purchasing
Ami – Sales
Second, in the PR work flow, create the grouping as above. You must add the condition, and the condition will be attach to grouping you used in the employee list.
Alice
can u be more clear regarding this issue…
Dear Nagendra
There are three ways to set Workflow Approval as follow:
  1. User based
  2. Role based
  3. Hierarchy based
In first two options either you can select individual users or user groups so approval will go to either selected user or users in selected groups.
In third option hierarchy is defined in HR or Basic module in following manner:
Positions are defined and in position “Report to Position” is defined and then one position is linked to one employee, so by using this method Document submitted by (Example) Accounting Clerk will got to Account Manager and Document submitted by Purchasing Clerk will go to Purchase Manager (depending on Positions & Report to Positions)
Hope things will be clear may you require any more assistance please let me know.
Regards
Muhammad Saad
