I’m trying to create a class that allows for batch receiving and register pickticket for pos,
All the code samples that I found are using : purchFormLetter.createParmUpdate();
This method is deprecated in AX 2012,
All what I need is to specify the receive now quantity on the PurchLine, then use the chooselines method , and specify the specqty to use receiveNow, correct?
But I got a couple of errors:
The choosedLines display a dialog that allows the user to modify the query, I do not want this dialog to be displayed since it’s a batch job and will be called from a web service
when I specify All for the specqty, it works fine, but when I specify ReceiceNow, it gives an error
I do not have to use any specific AX classed , so if you have any code to receive a specific qty in AX 2012 in any other way, that would also help
