Hi all the master, i have a problem with prepayment invoice. After i created a prepayment for a PO, then i wanted to create invoice for the prepayment. When i click on “Prepayment invoice” under PO’s invoice tab, i got the error as below:
The state of the source document or source document line could not be updated.
Removal of suspension of recId allocation for table VendInvoiceInfoTable has failed.
Microsoft.Dynamics.Ax.Xpp.ErrorException: Exception of type ‘Microsoft.Dynamics.Ax.Xpp.ErrorException’ was thrown.
at Dynamics.Ax.Application.SysRecIdSequence.Removerecidsuspension(Int32 _tableId) in SysRecIdSequence.removeRecIdSuspension.xpp:line 23
at Dynamics.Ax.Application.formletterParmData.Removerecidsuspension() in formletterParmData.removeRecIdSuspension.xpp:line 15
at Dynamics.Ax.Application.formletterParmData.Catchall() in formletterParmData.catchAll.xpp:line 9
at Dynamics.Ax.Application.formletterParmData.Createdata(Boolean _append, Boolean ) in formletterParmData.createData.xpp:line 63
at Dynamics.Ax.Application.PurchFormletterParmDataInvoice.Createdata(Boolean _append, Boolean ) in PurchFormletterParmDataInvoice.createData.xpp:line 3
at Dynamics.Ax.Application.PurchFormletterParmDataInvoice.chooseLinesServerIL(Object[] _pack) in PurchFormletterParmDataInvoice.chooseLinesServerIL.xpp:line 32
at PurchFormletterParmDataInvoice::chooseLinesServerIL(Object[] )
at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
at Dynamics.Ax.Application.SysDictClass.invokeStaticMethod(Object[] _params) in SysDictClass.invokeStaticMethod.xpp:line 26
at SysDictClass::invokeStaticMethod(Object[] )
at Microsoft.Dynamics.Ax.Xpp.PredefinedFunctions.runAsInvoke(String className, String staticMethodName, Object[] parms, Object[]& exportInfolog)
Appreciate if you can tell me what’s wrong about it. thanks!
