Purchase order
Hi All ,
How to delete the Approved purchase order and what are the tables need to consider to delete those PO’s in AX 2012 ?
Thanks in advance.
What does it tell you when you press delete?
You mean PO with Approval status= Approved? If yes, then i think you can delete directly without considering any other validations.
The issue was that change management was configured and you cannot delete it, you must cancel it. The only alternative is to write a job the cleanse the tables.
