Purchase Order RTC 2013
i am facing problem while making a post ie
Microsoft Dynamics NAV
The Bin does not exist. Identification fields and values: Location Code=‘EMS’,Code=’’
OK
when i am trying to insert the value by dropdown in bin Code then it is not accepting and also not giving any error.
You need to create Bin in Bin code master which will then available in dropdown…
When you have bins turned on (bin mandatory) you must always select the take bin, weather it be on the PO or the Whse Shipment.
