Hi guys when i make purchase order and write what i purchase then i make post receive it take more time may be 5 minutes to make post then receive to one order.i think the problem in network but i test in computer have good connected to network but no benefit
the message error found in this link
www.mediafire.com/…/
why this problem make i think more time and try more time but no benefit
Hello,
check better your setup on warehouse->setup->Inventory Setup
I think you have marked “Automatic Cost Adjustment” = something different then NEVER
This mean after each inventory movement the Adjust Cost procedure calculate your unit cost causing the slow performace.
I don’t know your business but usually you can get the best performance using as setup NEVER and then schedule when the end-user are offline the report R795
See you,
Even if automatic cost sdjustment is checked you should still be running adjust-cost batch job on a regular basis.
what you mean about this line “still be running adjust-cost batch job on a regular basis.” please clear to me this line please
What different between Never and another options and if i changed now to never are this will make problem in records already works
I would also like you to check on Analysis Card whether Update on Posting is enabled if you have define any analysis view for Purchase …
No analysis view found in analysis card .and what the relation between this analysis view and problem
