Any suggestions on how to undo a posted receipt that is not an inventory item?
I posted an invoice from the PO and I deleted the number in the Qty column instead of deleting the Qty to Invoice column…
Would you be pleased to state the version of NAV in use?
I am not sure, I believe it is 2007
Dynamics/NAV
Using standard NAV, you can’t. [:(]
You have to complete your purchase (post it with option Invoice) and then create a Credit Memo or a Return Order.
