Purchase order - Foreign Trade tab
Hi masters,
I gone throgh the F1 for the following fields , i did not understand. so i asking the question about that.
what is the use the following fields , please explain with a suitable example
1.Transction type
2.Transaction specification
  1. Area
please explain about these fields with examples.
Do not copy that F1 .
They are Intrastat required fields. If you need to report Intrastat then these fields can be used, although they are not mandatory on the purchase order because you can fill this in when you do your intrastat declaration. This is what they are used for when I implement anyway, they may have other declaration purposes in other localisations.
What do you know about Intrastat?
https://www.uktradeinfo.com/index.cfm?task=aboutIntrastat
