Purchase order--> all tabs on header disappear when we click on a particular PO
Go to Accounts payable , All purchase order, click on a particular PO, While doing so all the tabs like Purchase , Manage , Receive , Invoice and General gets disappeared .
Pls help
Ask a developer to review it, I would suggest you have modified something and it is not working. Alternatively remove the usage data in this area (but it does not sound like a personalisation)
Hi Adam
We did install few hotfixes . Could that be the reason?
The developer you are going to ask would be able to answer this.
After you installed hot fixes, did you compile and generated full CIL? If you haven’t, suggest you to do the same.
