Purchase Ledger - Month End Routine Question
Good afternoon,
I work within a business where the Purchase ledger closes 2 days before the financial period end.
I would like to know if anyone has used or come across any standard functionality/validation within AX Version 4.0 or 2009 to prevent invoices within Purchase Ledger journals from being registered and therefore posted into the General Ledger. Ideally I would require the invoices to be posted into the next financial period.
Thanks and kind regards,
Tom
I don’t have AX 2009 in front. From memory, you should be able to control this module status tab in General ledger period setup.
I believe closing purchase order is all you need.
