There are lines with qty, unit cost and line amount is not 0. Is there any setup to enable discount for G/L account. If I select Item instead of G/L, it is accepting the discount amount.
If you retreive the (default hidden) field “Allow Invoice Disc.” into the lines and put a check-mark into that field, you’ll be able to grant a Discount Amount.
