I am having issues with setting up Approval templates. I am getting an error message stating
Approval Setup Primary Key " does not exist.
Any suggestions ?
Thanks…
Any suggestions ?
Thanks…
The system relies on information that is set up in the Setup tables. If there is no such record the system will generate this error message. You will have to create the record by entering some values into the Approval Setup. Sometimes just opening up the form will create the initial record.
Define the approval setup:
Administration>>Application Setup>>Document Approval>>Approval Setup>>User Setup (Bottom, right hand side button)
or From Object Designer Form (Approval User Setup) No. 663.
I believe field in the form are self explanatory.
