I need to remove article.
When I’m trying to do it I got the alert that I can’t delete article because properties values still exist.
How can I delete property values and where can I find them?
Is this related to custom functionality?
No it’s not.
I have article in my list of articles. Article means - product. It is in product information management.
What is the full error you are getting?
Property settings cannot be deleted while dependent Property value exist. Delete dependent Property value and try again.
I don’t think “Property settings” is something related to standard.
My property setting is related to product. Properties contain additional information which I can add to product in sales order line.
Can you tell us the path to configure the property for a product?
Product information management/Common/Released products - if I’m going there I can choose my article/product from list and on action pane choose property setting
I don’t see it in stadard? Which tab?
In general the type of error is used restrict the deletion and to maintain the data integrity.
Example: When you try to delete a vendor, the system will not allow you to delete the vendor if the vendor is assigned to a product as primary vendor.
In your case you are trying to delete the property though there are values related to it.
Yes, that’s right.
I’m working in test environment now.
Not all settings work good. Ok thank you for help.
Post is closed.
