We are running Microsoft Business Solutions 3.70, Ceres 2.5 IE NAV 4.0 SP3 on Windows 7 64bit machines. No problems with any machines but one. Machine appears to be setup identical to the rest but even when NAV client is run under an admin login it is requesting admin rights to run then errors.
Welcome to DUG!!!
Can you paste exact error message here… ??
I completely turned off UAC, uninstalled the entire program, restarted, reinstalled, restarted and still get the same message.
Problem signature:
Problem Event Name: APPCRASH
Application Name: fin.exe
Application Version: 4.0.3.23305
Application Timestamp: 4511b8e2
Fault Module Name: fin.exe
Fault Module Version: 4.0.3.23305
Fault Module Timestamp: 4511b8e2
Exception Code: c0000005
Exception Offset: 000aaef6
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 1e95
Additional Information 2: 1e952f4a5edef63a298b9a5d8fe5346d
Additional Information 3: b2af
Additional Information 4: b2affee4eeea691dfa0dd4bcd4ba62f9
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
