I am using project module in which I am scheduling activity. The Link is START-START & the link type is SOFT. The scheduling of all activity using the said link starts at the same date & time .Actually link type soft should provide lag time which it does not show. System considers Link type Hard by default. Please suggest…
Hi ncupasani,
Did you ever find a solution to this problem? If yes, would you mind sharing it with us?
