I need to create Project Contract using X++ code in AX 2012. Can anybody plese help me with the code???
Thanks in Advance.
Thanks in Advance.
Hey thanks for the link but I am not able to use it. Can you please guide.
Not sure what issue you are facing. Please can you elaborate?
Where exactly should I use the code?? And how can I call it??
The code sample I posted is AX job. Try the following -
With the above steps, you can rapidly build a working solution.
Obviously there are other ways to build rapid solution as well. It all depends on actual requirement, your X++ experience etc.
Hi Harish
I am very very thankful for your continous support. I really appreciate it.
Can you please tell me how do I improve my X++ skills. Any book or training you can suggest??
Thanks in advance.
Hi Harish ,
Below code will help you
ProjFundingSource projFundingSource;
NumberSeq numSeq;
CustTable custtable;
ttsBegin;
projInvoiceTable.clear();
projInvoiceTable.initValue();
custTable = CustTable::find(“Give your account number”);
numSeq = NumberSeq::newGetNum(projParameters::numRefProjInvoiceProjId(), true, true);
projinvoiceTable.ProjInvoiceProjId = numSeq.num();
projInvoiceTable.CurrencyId = “USD”;
projinvoiceTable.Description = custTable.name();
this.parmprojectcontract(projinvoiceTable.ProjInvoiceProjId);
projInvoiceTable.insert();
projFundingSource.ContractId = projInvoiceTable.ProjInvoiceProjId;
projFundingSource.CustAccount = “Account number”;
projFundingSource.FundingSourceId = CustTable.name();
projFundingSource.FundingType = ProjFundingType::Customer;
projFundingSource.PaymentTermsId = “Net8”;
projFundingSource.PaymentscheduleId = paymentform;
projFundingSource.editProjFunder(true,projFundingSource.CustAccount);
projFundingSource.insert();
projFundingRule::createDefaultFundingRule(projInvoiceTable.ProjInvoiceProjId,projInvoiceTable.RecId);
ttsCommit;
Thank you
