Can you plz suggest how to achieve the below requirement in D365 FO.
As per out of box functionality default dimensions can be assigned only at project level, by default any transactions which are posted to project dimensions are picked from the project level.
we need to override this out of box functionality and make category dimensions as a primary dimension for postings and secondary dimension postings should be from the project.
Out of box functionality gives options to assign main accounts but not financial dimensions.
AS IS
To BE
Dimensions structure should be incremental as per the accounting structure
