hi,
I want progressbar in my application.
i used msdn.microsoft.com/…/aa841990.aspx this example. but in this example setTotal method parameter is given static. in my case i do not know total count of records. so how can i set parameter of setTable methd dynamically.
You can set Total = 0. The dialog will display, although it obviously can’t show any progress bar then.
I didn’t get the sentence about “setTable”.
Thanx for reply. It was setTotal not setTable my mistake. setting 0 will not help me because i want progress bar as well as remaining time.
If you process 100 items and you don’t know the total number, how do you know whether 100 represents 1%, 50% or 100%? The same is true for remaining time. It simply can’t be done.
I have Another question I want to set focus on my progressbar is it possible. Some times it minimize directly it means it is not visible on main window.
there is a tutorial on progress bar in the forms…
