Progress bar for xml port
Hi all, im trying to develop a progress bar for a heavy data xmlport using this triggers:
OnPreXMLport()
window.open
Main Dataitem - Export::OnAfterGetRecord()
window.update
OnPostXMLport()
window.CLOSE;
Progress bar works great, my problem is that the window.open() shows up the “Do you confirm you want to change the key that identifies this record” message. Any idea for skip this message?
Thanks in advance
Can you post the C/AL code you are using for the window.open
Hello, thanks for the reply.
My code is very simple,
Window.OPEN(‘Exporting @1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@’);
Best Regards.
Standard stuff . Is the message displaying in the dialog or a different message box. I suspect that the message is not related to the dialog box but just refreshed as the dialog is displayed. Have you tried to debug to see where the message is generated from?
Hi, thanks for replying. I just know it happens with the window.open call, if i comment this xmlPort works great without any message.
Is the message displaying in the dialog or a different message box.?
