In Nav40 when defining workcenter with consolidate calendar, capacity usage on machine center doesn’t reflect in usage of work center capacity. So you graphically see the capacity usage on the machine center, but if you hide machine center and check capacity on workcenter level, it seems totally unused. Is there something I forgot to setup ???
Good Day: Did you setup on the Machine center the Work Center Group Code? Did you run the Planning Calendar for each Machine center? Steve
