production posting
hello…
does anybody know the exact impact of the Post excl. transaction type check
box on the production order parameters?
thank you
If I am not wrong the selection/non-selection of this parameter gives you different levels of posting details (posting amounts are summarised). I think it is easiest if you finish a production order with and without this parameter selected and compare the difference in the ledger postings generated.
Hope it helps,
Ludwig
hi,
thank you for your help i will try it and notice the difference
Abeer
