While I checked production posting inquiry, there is no amount displaying in the in Report as finished column, its showing material consumption and costing too. but not showing in Report as finished.
If your production parameter is set to actual costing it will post the value from the item record, if it is set to estimated it will process the cost at the point of estimation using the known costs of the components. Known issues are if you choose actual and have no cost the RAF is zero and I believe if you skipped the estimation step and post by estimation this causes issues. End production and it will actually cost it.
