It mean for drawing process, every piece produce, the process cost is USD1. Bending process cost is USD3/ piece. Both operation run at the same time.
I create production order (qty =1) , when i Update> Estimate. AX calculate the process cost correctly, which total are USD4.
I START the production order without posting any journal. Then i create a job card journal, enter the Good qty as 1 for DRAWING operation only , and POST.
When i click on Inquiries> Route transaction. AX show my route total cost are USD2. The calculation as below:
Operation Value Amount
Drawing 1 USD1
Bending 1 USD1
My question is:
Why i enter job card for Drawing operation only, AX will capture both drawing and bending cost?
Why the bending cost is USD1 , not USD 3. It follow the primary operation cost?
I would guess that because it is a quantity cost allocation and you can only have one quantity from the operation it is taking this to be the primary. I would expect the setup and process cost to alter with the production, but to verify this I would need to configure the system as you have but I do not have time, I would suggest you contact Microsoft and ask the question.
