We are starting to use our production system finally and through all of my testing i didnt come across this until now. When we try and post a sales order we are getting an error about the item is not on inventory and i found out why is because it is creating a reservation entry when we create the production order. Is there a way to keep this from happening?
So no one has any idea about this?
It depends how the production order is created and the setup of the item. You have not told us your process or settings. If you run planning on a period based requirement type there would be no reservation from the sales order. I am guessing you are creating the production order directly from the sales order, then it will reserve, the question is then why you are having issues processing it - surely you have finished it and booked it in, but if these are at different dimension group requirements this could impact - your version of AX is also key here.
