How would you setup labor and overhead against a parent item?
Hi, The north american concept of labor and overhead is not directly supported by Axapta. You can “only” setup a blended rate in standard Axapta.
You could add a small mod to create a new cost category of overhead as well as process, set up and quantity to the cost categories. In this way the system can then split the labour and overhead out. it is interesting, but we have teh same problem in Europe.
