Hello all,
I am looking to find the maximum load a model can currently take. My company sells a highly configurable product.
The models will have a maximum of 19000 BOM Line Items, 835 Attributes.
Looking at the current models we have I created a Test model to see if you product was compatible with AX.
There is a root component with the following criteria;
- 300 Attributes
- 150 Constraint Tables
- 6 Sub Components (which in turn have 10 attached to each of them)
- 1800 Pass down calculations (to pass attribute values down)
- 0 Bom Lines.
Overall Model has, all the attributes in each subcomponent, constraints on the root components immediate children, ;
- 18000 Attributes Total
- 19800 Pass down Calculations
- 1050 Constraints Tables
- 18000 total BOM Lines.
The results were disastrous. It took 15 minutes to open the model in a sales order, the Constraint tables did not activate, they had a curved blue arrow on them drop down menus, and there was a 2 second lag on each choice being answered.
My main questions to anyone reading this would be;
- Have you seen functioning product configuration models of this size?
- Is there a better way to have attributes in a child component inherit the values better?
- What sizes does your company currently use?
- Is it hardware issues rather than software?
Cheers
Tom
