Procurement
  1. how user can identitfy tat a user cannot edit posted po
  2. wat will be result aft canceled po is being finalized…will the status of po change. if yes wat will be de new status. is changes happen any other area during this process?
  3. how to reject item aft product receipt is posted. (step by step process)
  4. how to reject item aft invoice is posted (step by step process)
Add document status in all Purchase order where document status will tell weather the user should edit the PO or no.
  1. wat will be result aft canceled po is being finalized…will the status of po change. if yes wat will be de new status. is changes happen any other area during this process?
any po if it is finalize then it will not be editable and will not be usable for any other purpose.
  1. how to reject item aft product receipt is posted. (step by step process)
open product receipt and you will find correct option click and change as per your need and post.
  1. how to reject item aft invoice is posted (step by step process)\
you cannot reject item after posting but you can create credit not for the same or return purchase order for the same.
hope this will clear your doubt.
Skype ID:- hacker_ng
