We are using Navision 2.00A. The problem is we are trying to run a report but do not want to get the print out. However if we set the report properties to be Processing Only, it won’t be able to run. Is there any command as SAVEASHTML in Navision 2.00? or is there anyway we can run the report without print out? Thanks[?]
Navision, Can you supply a bit more detail about your requirement. Processing only reports are usually used to process sets of records -is this what you are trying to do? Regards, Chris.
Hi,Chris, Well, the answer is Yes. Actually, my problem is similar to the topic:http://www.navision.net/forum/topic.asp?TOPIC_ID=5956 how to invoke a report in the other report.
