Hi guys!! How can I verify in the system if the client has Process Industries installed? Is there any menu, option, etc., that I would only see with this installed? Thanks for your help!
Regards!
Regards!
License Information - Partner Modules - it would be listed in here.
It will also be listed in the configuration.
In Production you would see Batch Orders and Formulas.
The other option is,
Help (Alt + H) → where you will be able see the Process Industries build number.
Thanks Kranthi also for your reply, I couldn’t find it in the help documents. But finally it was a confusion, the customer thought Production III = Process Industries.
Regards
Héctor
In the help section(Alt + H) along with different help documentation you will be able to see About Microsoft Dynamics AX. Click on that, you will be seeing the Info with Process Industries and the related build number that has been installed.
