procedure for generating the subcontracting production order
How can i generate a subcontracting production order? waht are the setups or prerequisitions required ? Explain the work flow in detail.
Hi Prakash,
This toipic discussed before see this link,
http://dynamicsuser.net/forums/p/15941/76115.aspx
http://dynamicsuser.net/forums/p/32870/172722.aspx
You get a good example defined for you step by step in the production manual, follow this through first.
hi Rajkumar,
Thanks for replying, but i need the setup to update the subcontracting orders.i.e., if am process the subcontracting orders that orders is not updating in the subcontracting work details.(In AX 2009, Production>common forms>subcontracting work details).
Prakash.
Look at the advanced filter on that form and check your orders meet the pre-set criteria. Also it depends what you mean by “updating” and this is a completely different question to the one you asked.
