problems with zup file
Hi, Here is my problem : in the menu contacts i set some filters on the contacts and i then open the contact card with this filter. now if there is only one contact with this filter and i delete that contact so there are no contacts with that filter and i then close the contact card and i try to reopen the contact card i get an error that the last contact that i deleted does not exist. if i close my database and delete my zup file and open my database again then i can open the contact card. can somebody tell me what i have to do to solve this thanks in advance, Wendy.
Hi Wendy You could remove the filter before exiting the contact card, and then it will not try to re-filter on going back into the record.
Hi Removing the filter will work. If you forgot this: Another way would be (without deleting the zup) to make a change on the form in the designer (one letter in the documentation is enough). Then the form will be cleared on your next login. bye André
Wendy, If this is going to be a persisent problem you could also change the SaveTableView property of the form so that the TableView setting are not saved to the zup file. Chris.
quote:
A simple compilation of the Object should be enough - there is no need of changing the object. (Not tested [:D] )
