There are some problems with the log in, in the Web shop for version 2.01 W1. The customer can’t be found when you try to log in. There are no specific problem when you register en new customer related to the purchase, but when you try to log in again it fails. The message displayed on the webpage is the same message displayed when you try log in with a incorrect password. “Unable to find Customer ID/Password”. så på
I believe you use the same machine (for demo). If yes then you need to clear all the offline files and reload the page. Other than that you should narrow down the problem, for example first of all, is it happen also when you create new customer from NF (customer card>fucntion>create password)? Then you need to check maybe the message is stranded in NF email or even in queue. Pls give more details. goodname
