Hi guys, I would like to export objects in text format (File-> Export) but this message appears :You do not have permission to run the ‘File, Export, Text’ sytem".What is the problem?? Thanks
Probably you don’t have the right license. I’m not sure which granules exactly are required, has to be “Application Builder” and/or “Solution Developer”. If the license is not the issue, than maybe you have insufficient user-rights …
Customer licenses usually don’t have this option as the “normal” customer doesn’t have these kind of advanced programming related granules. Saludos Nils
Application Builder… Julien, take a look at this thread, it may help to clarify things… http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=16923&SearchTerms=Application,Builder
