problems with posting an item
hallo, everytime if i want to make a salesorder with item 70000 i get the following message The Date does not exist=< identification fields and values: period type=‘week’,period start=’’ period type:week best regards, naessens wendy
Hi, This is a bug in the Attain 3.01, it is solved in the 3.01a and b versions. You can ask for the new version from your NTR or NSC. This appears only when you have setup locations and the stock for the item is not present in that location. Note: If you have stock of the item you will not get this message as the Bug is in the availability management code of the program. Thanks, Best regards, Prashanth NCFC, NCMC, NCSD pbg@navilogic.com
