When I try to export list of posted invoces (Sales & Marketing → History → Posted Invoices ) by pressing “Send To Microsoft Office Excel” icon in the tool bar, I get an error pop up displaying below message:
“Problems during load”.
The log file is as below:
XML ERROR in Table
REASON: Bad Value
FILE: C:\Users\younn\AppData\Local\Temp\39\Posted Sales Invoices - 1.xml
GROUP: Cell
TAG: Data
VALUE: 200606/200607
I did some testing and found out one of the posted invoices has its external document No. field as 200606/200607.
Without this particular invoice, exporting to excel wokrs fine.
there is no primary key for list. only for tables we have primary keys. to check the primary key select “Sales & Marketing → History → Posted Invoices” and press ctrl+F2 , this will take you to the dsign of this post. press shift + f4 to view the properities, in the source table check the table name, now go to that table and check for the primary key by going to design and press alt+v+k
i did the same way you described. i could export it dear. check whether there is any problem with your system. because we could export with slash in the export invoice.
There is only one Primary Key per table in Navision and the values for that are unique.
You can see the primary or first key for a table via the object designer and using the alt+v,k or you can use View, Keys from the Tools, drop-down menu.
In Table 112, Sales Invoice Header; External Document No. is part of one of the secondary keys for that table (it is appended to the Sell-to-Customer No.) Secondary keys may be non-unique.
As for the original question; check your lecal settings (Control Panel) and the default style sheets that are used for exporting data from Navision into Excel.
Shona I don’t think you have a clue what you are talking about, and you are only confusing the issue by adding wrong information. Primary key AS I SAID ABOVE is “No.” if you don’t know something and are just guessing, then please make that clear otherwise its very dangerous to state things as though they are facts.
I do reember an error something like this, in the very first ver of 5.00 but I thought it was only if the name or caption of the form had a “/” in it, or maybe the tab on the form. I am pretty sure that was fixed in the very first of the hot fixes. Have you tried removing the / from a specific order and proven that its is 100% certain the reason for the crash
mmm it is set as secondary key! i thought it was clear from what jonathan said!..and for your kind information i do know what 'm speaking about! i didnt see the table clearly before! but when i did, i just saw john’s post so thought snam will be knowing i made a mistake!
And david, i know you are experienced in this field and i respect that, but that doesnt give you the right to criticize others for their lack of knowledge! if you know and are willing to help then that fine! thank you! but dont be rude to others!
you have already made funny of me in my previous post! and the first time i posted you were really rude to me saying that i shouldnt use short forms! but i just mended my ways and 'm using full forms now! so you can try being gentle once a while!
You are still using some of your SMS text which is still very annoying.
BUT I was not commenting that you don’t know something, we all have to learn, I was commenting that you stated repeatedly information that is not correct.
