Hello Navision User Group.
First of all, thank you very much for your time.
In my journal i have problems using the first shortcut dimension:
I cant find the collumn for Dimension shortcut 1. When i try to add collums i can only find dimension shortcut 2-8, but number 1 is missing.
Ive posted a screenshot below. The language is danish but as you can see i can only add the shortcut dimension 2-8 and not 1. Its a problem for me because i have only 1 dimension and in the general ledger setup it is automatic set to be shortcut dimension 1 (so right now i cannot use my only dimension).
Im using Nav2015. If you need to see any other screenshots from my system i can post it in english when i get home tonight (my version at home is in english and right now im at work).
I really hope someone can help me.
best Regards,
Simon.
