Problems with decimals odbc link from navision
Everything works except the decimals. I get only integers in stead of decimals? Even if i try to use round() in VB6. Is there a problem with the odbc version of 2.01 or am i missing something?? Regards
Hi. There are some problems in the early versions of ODBC. The decimals only work in 2.60E or plus. Try to upgrade your ODBC. Regards.
Thanks, But i found the solution, change the , and the . in the configuration screen
