Problems upgrading from NF2.6
Morgen! I’m trying to upgrade to NA by folowing the manual what is attached to NA instalation but unfortunately I can’t get further then to chapter 2 2.3 checking for Duplicate Names step 2. I get NF error message that I don’t have rights to run codeunit 104018… although I have all rights. Is this a known problem or something else? BR, J.K.jr.
Have you got a Solution Developer License ? If you do Contact your NTR and report them your problem, maybe your developer license has not been configured properly. ###### Tarek_demiati@ureach.com
Beginning with the V2.5 or V2.6 upgrade toolkits, licenses had to be upgraded to allow running the Navision Upgrade Toolkits. Tarek’s advice is correct. You need an upgraded license. Dave Studebaker das@libertyforever.com Liberty Grove Software A Navision Services Partner
Thanks. I think you are right. J.
