Hi
I am new to Navision and I am trying to generate the report of consolidated budget of more than one firms, but I am not able to get the output.
Can someone helpme out with some solution.
Thanks in Advance.
Hi
Thanks in Advance.
Lookup the command CHANGECOMPANY. You can use this to read information from other companies. Are you using Nav consolidation?
Hi Dave,
I am unable to locate CHANGECOMPANY command.
What I want is that if I had more than one firms and I want to get the consolidated budget of all of them in the form of Report through NAV, How should I achieve this?
It’s not a standard report but you can develop it using the CHANGECOMPANY command. You will find info on this in the Help → C/SIDE Reference Guide.
