I’ve managed to sucessfully install Nav and BN and get it work… My first try was to create a new template “out of the box”, instead of using one of the standard.
For my try out, i create one similar to the ProdBOM Ver XmlPort.
My steps where:
1: create Xmlport and Xml event
2: Add a procedure in code unit 8000, in order to trigger the created event and send the notification to the BN.
3:In the OnInsert trigger of the required table call the created procedure .
4: Create the schema on the BN manager, define the fields, mail structure and so on…
5: Subscribed to the Schema
So far so good, after testing the mail it’s being generated , and it’s going to the email box defined on the user subscribed page, but the field that are defined on the xmlport are empty…
I allready tried to export the xml file, via a test codeunit, and the xml it’s correct and with values, but i still dont understand why when it’s called via trigger they came empty…
Can anyone help me on this subject?
Ps: i removed the MBS_Navision_field from my xmlport, just because i still didnt understand what does this variable do…Can anyone explain me?
Thanks in advance
Best Regards
JM
