I am facing two problems right now after the installation of NAV 2013 R2. I have NAV 2013 as well installed in my PC. Now after installation of NAV 2013 R2, i cannot run the objects directly from the object designer of NAV 2013.
Error 1:
One of the problem i faced is it shows the error that the instance ‘DynamicsNAV70’ is not your default settings. there may be security risks Do you really want to continue??
Error 2:
Another problem in another PC is i can run the tables and reports directly from dev. environment but only when NAV 2013 RTC is not opened. if i need to run any objects i have to close all the open RTC windows and then only i can run otherwise tables, pages do not run.
what may be the probable reasons and solutions for these issues. Need some guidance.
Suman
