Problem with writing in the file
Hello,
I did a small code which create a file if it doesn’t exist and write lines in it. I tried with the classic version of dynamics NAV it seem’s work fine but when I execute it with RTC version I have a message which tell that the file is opened by another application !!! (I think because there is a service which create the file …)
How could I correct that ?
My code is :
Path := ‘c:\TEMP\Test.txt’;
IF EXISTS(Path) THEN
ERASE(Path);
myFile.TEXTMODE(TRUE);
myFile.CREATE(nomFichier);
myFileWRITEMODE(TRUE);
REPEAT
myFile.WRITE(‘Line Text XXXXXXX’);
UNTIL xxxxxxxx;
myFile.CLOSE;
Thank for your help.
Sorry I made a small mistake when I was translating :slight_smile: :
myFile.CREATE(Path);
