I’m having a bit of a problem viewing projects from the projects list form. When I open a project for viewing through right clicking and choosing open or double clicking, if the project is not a sub project and has no associated sub projects, the form opens for a new record rather than displaying the current record.
However, if I choose the edit option the record opens up in the same form absolutely fine, and I can even click the edit button at the bottom of that form to return the form to view mode and it works absolutely fine.
The only difference I can find is that edit and view use different menu items to open the form however I can’t see any difference between the menu items that would cause this sort of problem.
I’m working with dynamics AX 2012 by the way.
