Problem with Navision 3.60 instalation
I met the following problem: i wanted to install Navision 3.60 Client on a machine with OS Windows server 2003 and MS SQL 2000 with SP3a but I couldn’t install him. The instalation wizard said only: “the program wasn’t install because was an error. If you want to acces the program, make a other instalation”. The instalation was breaking after MDAC and i try to make also a typic and custom instalation. Knows someone if is a problem of Navision or is a problem with rights and access mode from Windows?
