Before the installation finishes on WIN8 I’ve got this kind of problem (on two PCs using the same system data the error is the same)
(Nav 2013 R2 is installed on the root):
Microsoft Dynamics NAV Build 35473
Error Report
Server
Microsoft Dynamics NAV Server Components
Erreur irrécupérable lors de l’installation.
The service ‘Microsoft Dynamics NAV Server [DynamicsNAV71]’ (MicrosoftDynamicsNavServer$DynamicsNAV71) failed to start. This can be caused by one of several issues. For example, the password for the account that runs the service may be incorrect, or there could be a conflict in port sharing for the port settings for the service, or you have specified that the port for the server should be opened in the Windows firewall even though the Windows firewall is not enabled on the computer. For more information, see the event viewer.
I tried the Administrator account it’s the same problem.
By the way when I was attempting to open the installed NAV icon they say:
The program could not create a connection to the server.Do you want to try it again.When I say “no”: there’s a form telling that : You are not currently connected to a server.
Moreover, it’s impossible to start the SQL agent of DEMONAV database. Though the database is created.
Can you ensure the user you are using for installation is a local account whit administrative rights (the service account must not be a NT Service account)?
Please also check the event viewer for specific Return Code in order to have a more precise description of the problem
I’ve used the local account having the administrator rights . Later on I’ve even applied a funtion to log on as a service.
Nothing to do the same.
Then I’ve change into real administrator account deleted all database,reinstalled the demo Nav. Nothing.
As a return,the problem is indicated as following:
Windows Installer: Error: Service ‘Microsoft Dynamics NAV Server [DynamicsNAV71]’ (MicrosoftDynamicsNavServer$DynamicsNAV71) failed to start. Verify that you have sufficient privileges to start system services.
Which priveleges I need to have to start that Demo!
I confirm the error 3095 is related to workgroup: if the user chosen as service account is in a Windows workgroup (and not AD Domain) this prevents to run the NetLogon Service, which is a mandatory dependancy for Microsoft Dynamics 2013 R2 Windows service, and causes the installation problem you faced.
Should be enough to leave as service account “NT AUTHORITY\NETWORK SERVICE”, but I still suspect in this case the problem was related to some permission missing to create the service.
Then go to Services(local) (services.msc) find Microsoft Dynamics NAV Server[DynamicsNAV71], change the properties of this service: do not open as default NT Authority but set into your Windows account and it should look like: .\UserName
And finally start the service
Launch your application.
And it works! I can see my Navision Iterface! Finally!
Before installing Microsoft Dynamics NAV 2013 R2 components on a computer, you must remove (uninstall) any previous versions.
All RoleTailored components must be from the same version and build of Microsoft Dynamics NAV for the software to run correctly.
If you have either SQL Server 2000 or Microsoft SQL Server Desktop Engine (MSDE) installed on a computer where you want to install Microsoft Dynamics NAV, then you must remove it before you begin installing. The presence of either of these database products causes a Setup error.
I actually face the same problem. Now after changing the user of the service to my username the service needs a password but I never entered any as the installation of the demo never asked for any. Is there a standard password for the demo installation?
