problem with license file
Hi ,
iam getting a small problem with license file
The OS Cannot access to the file C:\Program Files\MS Dynamics NAV\60\Classic\fin.flf
Verify that the file type and attributes are correct
Iam getting above error when i try to import the license file.
Also after my work when i close navision and open it again i need to import the license again. Can’t we keep the
license file info completely.
Hi Veda,
  1. Are you using SQL Server? Then remember you really need to upload, not just import.
  2. Is the directory/existing FIN.FLF write protected?
Have you tried just manually to copy your new FIN.FLF into the …\60\Classic directory?
