So this is my situation - I have two databases - Originall database (Lets call it Database A) and temp database (we will call it Temp). Temp is Demo database (9-0) that came with NAV 2016 installation. These two databases are same build.
So what I did.
1.) Export all objects from A
2.) Export one company from A (this is new company with only setup, no other data)
3.) Imported objects from A to Temp and compiled them
4.) Import company from A to Temp with powershell (Import-NAVData).
After this i get error that I don’t have enough space. So I tried to investigate, ant in my sql server databse limit is 10GB, and I have set the autogrowth setting to 300MB, unlimited.
So I don’t get it why a company backup file that is 600MB large, cause database to grow beyond 10GB ?? Is there any normal explanation ??
Error was - Import-NAVData : Could not allocate a new page for database ‘Demo Database NAV (9-0)’ because of insufficient disk space in filegroup ‘PRIMARY’. Create the necessary space by dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup.
Error ocured because database reach 10 GB size that was SQL server limit. It is not logical that only one company 600MB size during import gives dabase larger then 10GB …
The short answer is yes, the database can easily grow to more than 10gb during the upgrade - Remember that if your backup takes around 600mb then the actual database size (with all the sortingkeys and flowfields) easily can be multiplied with 5-6 times meaning more than 3 gig - All data is stored at least twice during the upgrade AND the Transaction log grows to an insane size.
So upgrading is not done with with 10gig limitation database sorry.
(When finished you can do a SQL backup and the database will usually take up 3 times the size of an NAV2009 base when its converted to +NAV2013.
PS Dont set your autogrowth to 300mb - let be at the default value which is autogrowth 10%
Regards
Palle
PS. Be aware of that you might have to redo the upgrade again, depending on how far the upgrade went, you might have to start all over with the import.
Palle it’s late. Nobody was talking about NAV 2009, he wrote 9.0 = NAV 2016. [emoticon:c4563cd7d5574777a71c318021cbbcc8] [emoticon:591b528a84b3405eb929950ed66f384e]
And as I understand, then you’re not importing a SQL backup, but a NavData file. The NAV file is really RAW data, so I’m more interested in know how big the original database was.
The main problem here is the NAVdata format - it really has issues so its a matter of what version (Buildno) of NAV 2016 that is being used.
Secondly one must be aware of that the 600mb data is the RAW data and the actual database size is way bigger (6-8 times bigger) because not only of the sorting keys space but also the creation of the transaction log.
Besides it was never the intention of NAVdata-backups that it should be used with so big databases.
