I am using Dialog form(form from template) and i am connecting 4 tables as data source to that form (1 Master table and 3 child table). All the details are added to the form as Seperate groups(ie details of 4 tables are seperated as four groups). whenever i want to create a new record only the first group value is getting cleared not the rest of the three groups. can anyone provide me the solution for this problem. i want to clear all the field values whenever i press (ctrl +n).
Having a relation on table level is not sufficient, you have to also set a parent data source (JoinSource property) and the type of link or join (LinkType property) on form data sources.
