HI, I want to export some datas filtered according to some criteria. Datas are in two diff table. I cud able to filter one data Item with some filters. I cudnt filter the second data item. Is it possible to export into excell sheet with both tables data in row wise? Tanx in advance Tony
Hi tony,
Did you ever find a solution to this problem? If yes, would you mind sharing it with us?
