Hi everyone,
I am trying to import some data from a .csv file into a table I created using an XMLport.
I setup the XMLport as following:
Format : Variable Text
FieldDelimiter : <">
FieldSeparator : <,>
RecordSeparator : <<NewLine>>
When running it, I get the result in the following image.
What shall I do?
Did you try the following settings?
FieldDelimiter : "
FieldSeparator : ,
FieldDelimiter : "
FieldSeparator : ,
I treid it and I get the following error:
You cannot enter 'Bicyclette' in Decimal.
Sounds like that the second field in your xmlport dataitem is a decimal field (Amount?) and not the Description field.
No, the second field is Description and the fourth field is Unit price
I am using an XMLPort, not a dataport [:)]
Some questions:
what version are you on?
could you share the import file?
running XMLport on RTC?
I figured it out.
Infact, you were correct about the settings but when I tried themit didn’t work since I was using an Excel file with a .csv extention…
Now, I changed my file to a .txt file with the same content, I changed my settings the way you indicated **(except for the third one, it should be not <> )**and it worked
Thank you for your effort
Don’t use Field separator as comma better use it as TAB.
